Citect 2016 to 2018 update
I need to make a online update of a Citect 2016 project under Windows 7 to Citect 2018 under Windows 10. I have not seen a procedure that explains how to do it between these two version, the help stops at the 2015 version.
Do you have a procedure?
Can I combine the two versions?
  • Hi Pascal,
    There is a very comprehensive tech note on the GCS website here:
    https://softwaresupportsp.schneider-electric.com/#/okmimarticle/docid/tn3214
    It describes everything you need to consider for the upgrade.
    Also keep in mind that it is good to install the latest Patch/Update that is available from the product hub:
    https://softwaresupportsp.schneider-electric.com/#/producthub
    It is ok to run both versions in parallel or to mix the versions for a short time while you complete each node upgrade in the system.
    Hope this helps.
