CtAPI with Windows 10
I am using a VB.Net 2017 program that uses CtAPI.dll. My program worked well with Windows 7 and Citect 2016. After migration on Windows 10 (with also Citect 2016) my program doesn't work anymore. I also tested it with your application that I found in Toolbox 'wbCTAPIvbnet.exe', the problem is identical, I always have the following error when connecting connecting via ctOpen : An attempt was made to load a program with an incorrect format. (Exception from HRESULT: 0x8007000B)
Can someone explain to me what I need to do to make my program run on Windows 10 ?!
Thank you in advance.
