set(True = false)
aveva edge 2023r RUNTIME
Hello everyone
I would like to run two views simultaneously in runtime on two different screens. How can I achieve this?
  • Hello Mohamed,
    You can use two different screens simultaneously during runtime by utilizing both Windows Viewer and Mobile Access.
    Mobile Access (sometimes referred to as Studio Mobile Access or SMA) allows you to deploy an HTML5-based web interface that provides access to alarms, trends, process values, and project screens in a unified, easy-to-use "dashboard." This interface is optimized for smartphones and tablets (such as Android and iOS devices) but can also be accessed from nearly any computer using a modern web browser like Microsoft Edge or Google Chrome.
    Please note that your software license must support enough Thin Clients to accommodate all the users you expect to access Mobile Access at the same time. If you want to use SMA in multiple sessions simultaneously, you will need the appropriate license.
    You can find detailed instructions for configuring Mobile Access in the AVEVA Edge Help Manual, under the section "Thin Clients and Mobile Access." This section also includes installation tutorials.
    In summary, if you have a computer with AVEVA Edge installed and a modern web browser, you can run the project using AVEVA Edge and access the runtime through both Windows Viewer and Mobile Access. This setup will allow you to view the same project runtime on two different screens simultaneously.
    I hope this helps!
