Commands to manipulate InTouch from windows
I'm looking for options to manipulate InTouch with commands.
Someone told me that you can use view.exe /w"<WindowName> for example.
This way you should be able to open the another window in the running view application.
Is this true? I can't get it working.
I'm looking for this kind of parameters like /w and more.
Does anyone know this?
  • From what I can recall, it is possible to pass the application path as argument to view.exe but I'm not sure if it supports any more parameters than that. For instance, view.exe "C:\Apps\MyHmiApp" will attempt to open an InTouch app at that location.
  • The official parameter that I have found is indeed the application path.
    But there has been some information that there are switches to use as a command available.
    view.exe /ReadOnly should for example open the application in read only mode, (in some newer versions and in OMI).
    I would believe that any additional information on how to use parameters or switches has to come from un-documented suggestions from developers or techsupport.
    But going back to the original question of controlling windows externally is in some way a security risk.
    At least without any active control from the application it self.
    If this was a possibility, then I could, by using the ww_wdws.ndx file, review all available windows in the application and the open them one by one by using this switch.
    ie. view.exe /w AdminWindow
    Thus by-passing all built in navigation related security in the application.
    In the cases where I have seen external references controlling witch window to open, then it has to be a conscious decision from the developer.
    For example having InTouch reading from a config file when starting, opening windows based on the content there, or script checking node name deciding what window to open.
    For external triggers, have a Suitelink/OPC (or legacy DDE) client that triggers tags in InTouch that by scripting opens the desired window.
    But history has shown me that there are indeed a lot of tricks that are usually on a need-to-know basis, so I can imagine someone else has some experience that is closer to what Olav is asking for.
    Or any other view.exe /switch trick that is available.
