What configurations are possible in the InTouch.ini file?
The InTouch.ini file has a lot of different configuration settings already available.
But through the years we also have seen that you can add extra rows to the file to get more functionality or settings configured.
I would like to get/create a document that can show all the configurations that can be set in an InTouch.ini file for a StandAlone application.
Can you guys help me with this?
By default the following is already in the .ini file:
[InTouch]
AppMode=2
AppName0=StandAlone With Symbol Library
AppName1=
AppName2=
AppName3=
AppDesc0=New InTouch application with Graphic Toolbox symbols
AppDesc1=
AppDesc2=
AppDesc3=
LanguageBaseID=1033
InTouchView=0
EnableScreenResolution=1
ViewPortX=1920
ViewPortY=1080
ScaleForResolution=1
ShowCanvas=1
AssetTemplateFolderPath=C:\ProgramData\Wonderware\InTouch
DownloadSymbolPkgs=1
RepositoryName=
IdeManagedApp=
LanguageConfig=1
LangConfigNumber=0
SAOConverted=1
ApplicationVersionNo=1
WinFullScreen=1
WinLeft=-8
WinTop=-8
WinWidth=1936
WinHeight=1096
SnapOn=1
PromptNotifyOnClose=0
The things I already know are the following:
AllowPubAppEdit=1
If you want to continue editing your published InTouch applications.
SuppressRequireAckSignature=1
To make sure the AlarmComment does not get Overwritten by the Standard ack.
OmitCrossReference = 1
Skip the cross-reference calls during update use count process
