set(True = false)
Part no. for Aveva InTouch HMI Workstation 2020 100K Tag with I/O ?
I can find only 60K tags license part no. in the price list. How to manage 100K tags in Intouch 2020, Can we use two 60K tags licenses? or what will be another option to manage 100 tags. in a application.
  • Hi, This is a very sales-specific question and I would advise you to reach out to your local distributor / sales support, since the Flex license model includes several options for packages including a 100k InTouch license and it is important to get the full picture of what the customer need is before selecting a license.
    But to answer your second question, acquiring two  60k tag licenses does not equal one 100k (/120k) license. The limitations of a license does not support that way of adding licenses together to support a single InTouch Workstation. (at least it has never done this before).
    And the available part-numbers could differ between regions and versions etc.
    Most licenses are backwards compatible, so please look for a 2023 License in your lists, perhaps this would be easier to find?
    You need to find the correct license for your solution, but I am confident that your distributor could assist you with that.
  • Hi. Starting from version 2023, the 60k tags licenses were increased to 100k tags. The new part numbers match those for 2020, except that they have the numerical designation "231" instead of "20".
    As indicated by Richard earlier, the 2023 R2 licenses are backward compatible InTouch 2020, so applications must not be upgraded immediately, but we of course encourage doing so and taking advantage of both new features and cyber security improvments in the newer version.
    You may also want to look at InTouch Unlimited, which is a fantastic offer for larger sized applications (more than 100k tags) as well as for applications of any size which serve many simultaneous users.
