Area definition
We have just come up against an issue with the Area designation. This property appears to still be limited to 255 areas per project. In a small single site project I am sure that 255 is a wonderful upper bound but we build multi-site systems with multiple clusters. It would be really helpful if the Area property were significantly expanded to allow it to span Customer-->Site-->Building-->Location and maybe more. An unsigned integer would work nicely. I recognize that this may seem redundant with the capability of equipment design but as I understand it Area is the only filter that links user privilege with alarm screens so we need a lot more range than is present in the current limit. Is there any consideration to expanding the limits on this property.?
  • Hi Dennis,
    Do you know if you are using Privilege in your project? Each Alarm, Trend, etc can have a privilege and area defined. This allows quite a few more combinations, when used with Areas. Please see the following topic in the help:
    https://www.citect.schneider-electric.com/webhelp/citect800/#Privilege_and_Area_combinations.html
    It may also help to better understand your requirements. Are you mostly interested in filtering alarms or is it from a security perspective? E.g. the ability to control, acknowledge, etc.
    Hope this information helps.
    Kind regards
    Olivier
