SA Project- Alarm Page Column Fields
How can we customize the Active Alarm Page in SA project?
Would like to show other Columns and pre-set the width as it is always appearing to to small and fixed when opening the alarm page.
As an example I would like to show the ITEM column  (used in the Historical events ) on the Active Alarm page, and increase the default width of columns TAG and NAME.
Thanks,
Regards
Rune
  • Thanks,
    the ini file had the Format section set.
    All good!
    Rune
  • Great to hear Rune,
    Nice job Erik, nailed it.
    If you are using the main Citect.ini, I would really recommend to switch to using Profiles. Topology > Profiles. You can have multiple and then select which one to use either via the Setup Wizard, or if using Deployment, when you are configuring what to deploy for each computer. Profiles are safer, because if, you are like us and switch between projects or testing settings a lot, then they eliminate any chance of mixing settings. I also tend to use Setup > Params for everything that isn't configured in the Wizard.
