Labels in Cicode
In the CitectSCADA help, it states that labels can be used in cicode etc.
What I am trying to do is use partial subsitution to get the values of labels eg
i have a few labels defined:  _C_V01_PressureConstant, _C_V02_PressureConstant etc
i need to perform a partial substitution of the label in cicode where i need to specify the equip name using a string value...
FUNCTION ExampleFunc(string sEquip)
int value = "_C" + sEquip + "_PressureConstant"
//the value returned in 0  but the label has been set a value of 900
END
  • This will not work because labels are evaluated / substituted by the compiler. You cannot combine a label name from parts in runtime.
    You could implement a SELECT CASE statement with all labels spelled in full, for example:
    FUNCTION ExampleFunc(STRING sEquip)
    INT value;
    SELECT CASE sEquip
    CASE "V01"
    value = _C_V01_PressureConstant;
    CASE "V02"
    value = _C_V02_PressureConstant;
    END SELECT
    END
  • In this case you try to assign a string to an integer, which will result into a Hardware Alarm. There are several options:
    - V2016 : Define an extra item (PressureConstant) for your equipment type as Calculated Variable and add a parameter and use this in the Address field
    - V2018 : Put all the constants in a Map using some Cicode, use Equipment as the key name
    You probably want to use these constants somewhere, so in this it becomes easier to reference them.
