Scadacitect 2018
Encountered the following problem:
1. configured the OFS server through the OFS configurator, through the OFS client checked the connection. Connection successful, variables visible.
2. Configure Scadacitect 2018.
3. created a test page, output a variable, run the project, the variable is 0 (which does not match), in the OPC server the number of client connections is 0. There is an error in Citect IOserver not found, Cluster not found.
4. used as the OFSOPC driver in the m580 folder.
Please help if possible.
