Send Date types variables to M340 PLC
Hello,
I am trying to include in my software a simple interface to schedule maintenance of a sensor.
How can I send a Date type variable to M340 PLC?
What I have done now is use strings and split it in day, month and year.
Is there a simple way?
Thank you very much!
  • Neither MODBUS/TCP nor OFSOPC protocols support a data type for date/time, so it depends on your needs within the PLC application. Do you need the info as a string, or will Integers do the job as well? You could split your date/time into INTs for year, month, day, hour, minute and seconds.
  • Former Member
    Former Member
    Kevin, check Unity Pro Help - it describes Date type.
    The Date type in 32 bit format contains the following information:
    the year coded in a 16-bit field (4 most significant half-bytes)
    the month coded in an 8-bit field (2 half bytes)
    the day coded in an 8-bit field (2 least significant half bytes)
    Representation in BCD format of the date 2001-09-20:
    Year (2001)  Month (09)  Day (20)
    0010 0000 0000 0001  0000 1001  0010 0000
    Syntax Rules
    The Date type is entered as follows: D#<Year>-<Month>-<Day>
    This table shows the lower/upper limits in each field.
    Field  Limits  Comment
    Year  [1990,2099]
    Month  [01,12]  The left 0 is always displayed, but can be omitted at the time of entry
    Day  [01,31]  For the months 01\03\05\07\08\10\12
    [01,30]  For the months 04\06\09\11
    [01,29]  For the month 02 (leap years)
    [01,28]  For the month 02 (non leap years)
    Example:
    Entry  Comments
    D#2001-1-1  The left 0 of the month and the day can be omitted
    d#1990-02-02  The prefix can be written in lower case
  • Former Member
    Former Member
    On the other hand why not to send 3 separate values (Year, Month, Day) to M340 and convert it there?
