KNX special error 0x20000002
Hello,
Anybody know what going on?
I can't fix special error 0x20000002.
What is special parameter can fix it?
IOServer1.PORT1_BOARD1.IODev.PhysicalAddress = 0x0000
IOServer1.PORT1_BOARD1.IODev.InitTimeout = 300 seconds
IOServer1.PORT1_BOARD1.IODev.CacheLifeTime = 1800 seconds
IOServer1.PORT1_BOARD1.IODev.OfflinePollTime = 5 seconds
IOServer1.PORT1_BOARD1.IODev.MaxTransmistRate = 2000 bps
IOServer1.PORT1_BOARD1.IODev.InterFrameDelay = 100 milliseconds
IOServer1.PORT1_BOARD1.IODev.UnitType = EIBnetRouter
IOServer1.PORT1_BOARD1.IODev.CommType = 1
IOServer1.PORT1_BOARD1.IODev.LocalIPAddress = 10.22.20.241
IOServer1.PORT1_BOARD1.IODev.MulticastPort = 3671
IOServer1.PORT1_BOARD1.IODev.LocalPort = 3671
IOServer1.PORT1_BOARD1.IODev.MulticastAddress = 224.0.23.12
IOServer1.PORT1_BOARD1.IODev.IgnoreRouterDisconnect = 0
IOServer1.PORT1_BOARD1.IODev.TTL = 16
Init time Out  = 300 and it has been started Now
Unit worker thread started
Error: Unit warning   UINIT    000b PORT1_BOARD1        IODev                 Error_in_CMD-3   16   Generic 000011 Driver 536870914 (0x20000002)
SocketEventThread thread starting
OnStart function is triggered
1 tags found for unit IODev
Building read request for group address 0x0a04
Initial read request queued for group address 1/2/4
Transmitting Read Request of 17 bytes
buffer : 0EE35F68 bufferLength : 17
OS: Windows 10 Pro
Firewall is OFF
  • Have you looked the error up in the driver help?
  • Yes I looked but don't found how fix its special error.
    Discription of this is error:
    0x20000002
    ERR_INIT_UNIT_IN_PROGRESS
    Notification only – the unit initialization is still in progress
    I get value via Matricon KNX OPC without any problems.
    I tried to use special parameters of KNX driver and only when they set like that
    CommType = 1
    LocalPort = 3671
    Init time Out = 300
    the driver can recive some data from network:
    3 tags found for unit IODev
    Building read request for group address 0x0800
    Initial read request queued for group address 1/0/0
    Building read request for group address 0x0900
    Initial read request queued for group address 1/1/0
    buffer : 0EE65E28 bufferLength : 17
    buffer : 0EE65E88 bufferLength : 17
    Cpu called for channel PORT1_BOARD1
    buffer : 0EE660A8 bufferLength : 17
    buffer : 0EE65EE8 bufferLength : 17
    buffer : 0EE65F68 bufferLength : 17
    InitUnit called. Name: IODev, Network: 3, Logical: -1
    InitUnit for unit IODev is still in progress
    buffer : 0EE66048 bufferLength : 17
    buffer : 0EE65FA8 bufferLength : 17
    buffer : 0EE66008 bufferLength : 17
    16 bytes of data received from the network
    Update for UNKNOWN group address 2/1/104 received
    17 bytes of data received from the network
    19 bytes of data received from the network
    21 bytes of data received from the network
    23 bytes of data received from the network
    22 bytes of data received from the network
    12 bytes of data received from the network
    18 bytes of data received from the network
    But my values still have Bad - Device failure quality!
