html Report via Citect 2016
Dear,
I would like to generate a report in Citect using Html that is updated every 30 seconds. At the moment I have created an html page. but I have no idea what to do to connect my html page to Citect. I also looked at the Example project and found no solution. What should I set up in Citect 2016?
  • From memory there's an HTML page included as part of the default starter project. You should be able to use this to display your report, or have a look at it at least to see how it's created. There are HTML functions I believe that create the browser by replacing an existing AN object (e.g. a rectangle shape) and that you need to use to pass in the URL to. I don't have access to check at the moment, sorry.
  • You can run Exemple project, and then choose menu Help - Help. You will see Exemple project help and then open Exemple project pages - HTML report page. Good luck)
