Citect Scada 7.20 SP3 OID out of sequence
OID out of sequence. Set [OID]Reset=1
This error occurs when I compile my main project, with a I/O-device configured with the OPC protocol.
If I change it to another protocol the error dissapears.
When I look at the parameter [OID] reset, it says you shouldn't set it to 1 if you are using OPC drivers.
What does this mean, should I still change the parameter to 1?
Thanks in advance
Robin
