Hi!
I have a device created, dBASE_DEV, that creates an DBF.
I then call this device from a number of functions primarily using DevOpen in mode 0. Defined as mode 0, not relying on default 0.
This works fine when one function at a time opens the device, does it's thing, and then closes it.
But when I then have a loop that opens the device and each 10seconds scans through it just reading what´s in it, not closing it while sleeping. That function crashes when an other function opens the device.
It sounds like mode 0, shared mode, wouldn´t cause this. But Iv´e also tried mode 16, read only. But I get the same result with it crashing.
If I debug I get the error for bad handle, so I guess that the mode isn't as shared as one would think..
Am I using the device wrong? Maybe it can´t be opened from more than one function at a time?
