Viewing alarms from different servers on one client
Hi!
I've got two different servers, lets just call them A and B.
A running Citect SCADA 2018
B running Citect SCADA 2018 r2 update 2
On server B I would want to have a separate alarmpage where I could view alarms from server A.
The servers resides on the same network and all, so I suppose it will only require a proper made project in citect.
I've been trying to do this by just simply adding an alarm-page with A´s cluster. Only shows alarms from B.
I've then added an alarmserver to server B using the same cluster as A. The alarmserver starts, but the page still only shows alarms from B.
I´m running out of ideas, could someone point me in the right direction here?
Regards
Anders
  • We are missing some information Anders. To be able to work, Server configuration shall belong to the same project ( preferably divided into sub projects) So the Server know where to find each other. You did not mentioned if this is the case. It is more likely that this work if you have the same version.
