Hi Ana,
From the help "Runtime > Debug Runtime > The Kernel > The Cicode Profiler"
To activate the Cicode Profiler, you can do one of the following:
- Use the 'Profile' Kernel command (see Kernel Command Reference).
- Define type 4 when using Cicode function CodeSetMode.
- Set the INI parameter [Code]ProfilerEnabled. Refer to the Parameters help for more information
If you use the first option you see the result directly in the kernel.
https://gcsresource.aveva.com/Citect/WebHelp/citect2018R2/Content/Kernel_Commands_Reference.html
Profile: In the Kernel window, type "profile 1" to enable the Cicode Profiler, or "profile 0" to disable it.
Useful to understand what is going on in Cicode.
