Object Fill color based on SA colors
I want to develop something in the same style with the SA colors. Every object is filled with an array of 256  colors, for instance a button on the navigation page. The theme can be changed. Using the expression: Theme_Control_GetColorIndex(Button_GetState(DspGetAnCur())) the correct color is shown. Any idea how to copy the fill array colors from one object to another? I don't want to do that manually. I tried using the Graphics Builder Automation by using the following VBA script:
Dim GraphicsBuilder As IGraphicsBuilder2
Dim miOnColors(260)
Dim miOffColors(260)
Sub test()
udfCopyFillArray 1
udfCopyFillArray 0
End Sub
I have a breakpoint before udfCopyFillArray 0. I first select the objecct I want to copy the color array from in the Graphics Builder. After hitting the breakpoint I switch to my new object. Should be the PropertiesFillColourColourGetEx and PropertiesFillColourColourPutEx, but these don't work. Some magic with the citect.pal also I guess.
Sub udfCopyFillArray(iSet As Integer)
Dim iCounter As Integer
Dim iOnColourNo As Integer
Dim iOffColourNo As Integer
Dim iLimit As Integer
Dim iOperator As Integer
Dim iIndex As Integer
Set GraphicsBuilder = New GraphicsBuilder.GraphicsBuilder ' Set a new instance of the Graphics Builder
With GraphicsBuilder
For iCounter = 0 To 255
If iSet = 0 Then
iIndex = iCounter
.PropertiesFillColourColourGet iIndex, iOnColourNo, iLimit, iOperator
miOnColors(iCounter) = iOnColourNo
If iCounter < 20 Then
Debug.Print CStr(iOnColourNo) + "," + CStr(iOffColourNo)
End If
Else
iOnColourNo = miOnColors(iCounter)
.PropertiesFillColourColourPut iCounter, iOnColourNo, iLimit, iOperator
End If
Next
End With
Set GraphicsBuilder = Nothing ' Reset the COM-object
End Sub
Anybody an idea?
Thanks in advance!
Bas
  • Hi Bas,
    I haven't a had chance to look into this, but can you try the 'Ex' versions of these functions. I suspect that might be your problem.
    cheers,
    bradley
  • Bradley,
    There was a small error in the VBA code. Mondaymorning is so much better than fridayafternoon! Didn't get the types right. This code works fine:
    Dim mlOnColors(260)
    Dim mlOffColors(260)
    Sub test()
    udfCopyFillArray 1
    Sleep 100
    udfCopyFillArray 0
    End Sub
    Dim lOnColourNo As Long
    Dim lOffColourNo As Long
    If iSet = 1 Then
    iIndex = iCounter
    .PropertiesFillColourColourGetEx iIndex, lOnColourNo, lOffColourNo, iLimit, iOperator
    mlOnColors(iCounter) = lOnColourNo
    mlOffColors(iCounter) = lOnColourNo
    Else
    lOnColourNo = mlOnColors(iCounter)
    lOffColourNo = mlOffColors(iCounter)
    .PropertiesFillColourColourPutEx iCounter, lOnColourNo, lOffColourNo, iLimit, iOperator
    End If
    Next
    End With
    End Sub
