Trend function TrnGetTable
Does anyone know if this TrnGetTable would also retrieve data from the historian or just from the localhost?
  • Hi  ,
    The TrnGetTable only retrieves data from the connected Trend Servers. You can specify the Cluster the Trend Server belongs (optional). See the online help for more details:
    gcsresource.aveva.com/.../TrnGetTable.html
    If you are looking to get data from a Historian, there are a few options depending on your situation:
    - Data Exchange (ActiveX control) could be one approach.
    - Process Analyst can get data from Citect Historian (unfortunately no support for Wonderware Historian at this time)
    - SQL (https://gcsresource.aveva.com/Citect/WebHelp/citect2018R2/Content/Cicode%20Reference/Content/SQL_Functions.html) assuming your Historian supports this, there are some examples of this cicode usage in Example project.
    Kind regards
    Olivier
  • Thanks Oliver. I will try using the SQL method. I was searching for any documentation for the SQL database of the historian and could not find any. I dont know which table it stores the data.
  • Hi Mark,
    What Historian product are you using? If it is Wonderware Historian, it might be worth posting the question over at the Wonderware product forum.
    Kind regards
    Olivier
