Hello All,
Working with primary and secondary Modbus IO Servers in CitectSCADA 8.10 Update 12. With everything hooked up and online I can see the primary server comms in an ethernet traffic monitor and I can also see the 30 second WatchDog traffic to the Standby IO server. I can disconnect the primary and see the swap over to the standby and then re-establish primary comms and it will swap back.
The problem comes in when I disconnect the standby IO server. I wait for a few minutes but I do not get any hardware alarms. I can see the error using the kernel General window. It shows the channel going off line but no hardware alarms.
Do you know if there is anything I can check? I know this used to be an issue back in version 5 but supposedly it has been fixed.
Thank you for any help and have a great day,
Jim Spence
