Modnet communication
Hi all,
If you know the solution please share me.
Citect SCADA 8.20, Using Modnet communication(Modbus TCP)
 Slave machine: Yamato DataweighTm Omega, from Japanese machine vender, 1 unit.
www.yamato-scale.co.jp/.../184
https://youtu.be/pu5Z7Z6K_sM
Q1
There is only one slave IP address and one Ethernet port (502).
However, our SI want to communicate separately with multiple unit identifiers in one slave machine.
In the case of Modbus RTU, they specify each unit number for multiple slaves, but is it possible to divide one port into multiple unit identifiers and communicate with Modnet?
Q2
Can they change maximum Message Length in the Modnet communication?
I serched the manuals and KB but coudn't find the info about it.
  • Q1: I think it should be no problem to create multiple units at the same address.  Just configure them as different I/O Devices and give them each a unique number.  They will all be associated with a single Port that has the IP Address in its configuration.
    Q2: Yes. See the "Driver Reference Help" for the MODNET Driver.  There is a link to it from the Topology > I/O Devices page of Citect Studio.   See MODNET Driver > MODNET Parameters and you will see a parameter called MaxBits.  You can either set this universally, or if needed you can set a different value for each I/O Device.
  • Q1: For this to work, you have to define an I/O device for every slave ID within the device. You can then specify the different slave address numbers in the "Address" field of these I/O devices. All I/O devices can point to the same Citect Port definition which contains the IP address and TCP port (502) in the "Special Options" field.
    If you leave the "Address" field of a Modnet I/O device blank, or set it to 0, the driver will send messages to all slaves in the device (default behavior).
    Q2: The Modnet driver groups data into blocks of 2000 bits by default. This can be made smaller by setting the Citect.ini parameter [MODNET]MaxBits to a lower value. It cannot be made higher than 2000. Maximum message length is dictated by the official Modbus protocol (253 bytes) I believe.
  • Thank you for your reply. It was very good to know. I will try it by myself too.
  • Thank you for your detail answer. Easy to understand. I will try it by myself too.
