Polling CompactLogix (ABCLX) over ethernet radio
HI All, I was hoping someone may be able to share some tips polling a number of Compact Logix PLC via ethernet radio (4RF Aprisa SR+). Refresh cycle would be fine if under 5-10s.
Some colleagues have said that the Radios do not handle the ABCLX driver traffic. In the past, another PLC was installed at the base station radio that would poll the Other stations via CIP Read commands, Citect would then poll this PLC over the local copper network. (This obviously adds an additional point of failure).
Are there any parameters I can play with/alternative drivers I could investigate before I set it up on the bench?
  • I have my eye on device specific parameters (Scan Rate, delay, maxpending), as the stations don't require near real time refresh rates. (Wastewater Pumping Stations)
    [CLServer.CLServerPort]
    ScanRate=5000
  • Adjust System Overhead Time Slice in the PLC to the highest value possible.
Cheers!
  • Hi  ,
    I'd recommend checking out TN6243 and TN7589 for hints on what parameters to tune.
    I think try starting with ForwardOpenPoolSize=1
    Then look at increasing ConnTimeout and InitTimeout to double their default values.
    If that doesn't work well, you could look at enabling Modbus Server protocol on the CompactLogix (I assume this can be done) then use Modnet to poll the PLC over the radio link.
    Kind regards
    Olivier
