Daily Report Script Not Working
Dear All
Hi All Currently I have a project with the Aveva Plant Scada 2020 R2 (v8.30) program where the customer has a request regarding the Daily Report in Excel format and Trigger at 00:00 for every day, I have tried to make a cicode script with trigger every hour for more details you can see Cicode script below:
// To trigger save data per hour
FUNCTION trigger();
//INT A
Minutes = TimeMin(TimeCurrent());
det = TimeSec(TimeCurrent());
IF Minute = 0 AND sec = 0 AND A = 0 THEN
A=1;
write()
END
IF det >= 5 THEN A=0 END
END
//            To trigger save daily
FUNCTION write()
ExcelDate = Date (3) ;
NewFileName = ExcelDate ;
FileCopy("C:\Report_Harian_MS2.xlsx","C:\REPORT\Harian\Report_Shift_"+NewFileName+".xlsx",0);
Exec ("C:\Program Files (x86)\Microsoft Office\Office12\EXCEL.exe C:\REPORT\Harian\Report_Shift_"+NewFileName+".xlsx",6);
DDEWrite("Excel","C:\REPORT\Harian\Report_Shift_"+NewFileName+".xlsx","R6C3",Date (2));
DDEWrite("Excel","C:\REPORT\Harian\Report_Shift_"+NewFileName+".xlsx","R11C4",2000);
DDEExec("EXCEL.EXE","[Close(1)]");
DDEExec("EXCEL.EXE","[Quit]");
END
Local Tags
A = INT
NewFileName = STRING
Menit = INT
det = INT
From the results that I have done where the script does not automatically create an excel file in the folder, but if I do it manually (Via Button) the file is stored in the folder that has been created, I will also inform you that I have entered the cicode function ( trigger() )in the cicode object in the header menu that should be able to run automatically.
can you help me to solve this problem.
Thank's
