Mitsubishi TCP/IP MELSECQ Driver-Link Register variable tag Problem
Dear All,
We are going to upgrade old project with Citect version5.21 and MELSEC over TCP/IP (AJ71E71 card) based on Win98 to 2018R2 and Windows10.
After migration( changing driver from “MESLCQNA” to “MELSECQ”), there is no problem in communication, but I found “Link Register” variable tag does not work properly to change the status of “Link Relay” variable tag.
Here is the code:
"T1_CSET" variable tag address is: W13B0 (data type: INT)
"T1B_8" variable tag address is: B1208 (data type: DIGITAL)
Here is the code:
Button: Input On Command ---------------------------
T1_CSET=0;
T1_CSET1=0;
T1_CSET_P=0;
iCNT=TimeCurrent();
T1_CSET=T1_CSET BITOR 0x4000;
SLEEP(3);
T1_CSET=0;
Then “T1B_8” variable tag should be “true”.
And:
T1_CSET=0;
T1_CSET1=0;
T1_CSET_P=0;
iCNT=TimeCurrent();
T1_CSET=T1_CSET BITOR 0x8000;
SLEEP(3);
T1_CSET=0;
Then “T1B_8” variable tag should be “False”.
Any help is highly appreciated.
Best Regards
Mahsa Rassoulzadeh
Hooshmand Tavan Afzar Co.
E-Mail: m.rassoulzadeh@hta.ir
