Hi all,
As the documentation says the [Client]parameter determines the Cicode function to run when Plant SCADA DisplayClient component starts up.
When running as a service, the system services process also run this function at startup. Is it the normal behaviour?
Is there a way in cicode to know if the function is execute by system services or display client process (ProcessIsClient() is true for the both) ?
Thank you,
