Is there a parameter or function that I can check to identify that I am working in PlantSCADA Anywhere?
It is like the function IsWebClient() saying that I am in WebClient interface.
Thanks
Alex
Thanks
Alex
You should be able to use GetEnv() to read a Windows Environment Variable to tell if Plant SCADA is running on a remote desktop server.
Log in to an RDS desktop, open the Command Prompt, and type SET <enter>. It will list the environment variables. You can compare them with what you see on a normal client computer.
I don't have an RDS server available to test, but you should at least be able to check COMPUTERNAME to see if it is the RDS computer.
Thank you very much Eric,
We use GetEnv("ClientName")
Regards
Alex
