Ini file corrupt Plant SCADA 2020R2
I just installed Plant SCADA 2020R2, got everything set up. Runtime started once. I adjusted 1 ini file parameter and now my complete ini file is corrupt.
How can i get a new default ini file, because my Plant SCADA Studio does not start now because of the corrupt ini file.
Could someone please tell me or send me a default ini file for Plant SCADA 2020R2?
  • Save the following minimum parameters as Config\citect.ini and the new citect.ini should be good enough to start up Plant SCADA Studio. You could then merge your original settings into this new citect.ini file. Note once you open/close Plant SCADA Studio, more default parameters will be generated in citect.ini. Hope this would help.
    [CTDRAW.template.default]
    linked =1
    page =normal@HD768
    resolution =8
    style =sxw_style_1
    titlebar =1
    [CTDRAW.Versions]
    ctDraw =1
    [CtEdit]
    Backup =
    Bin = C:\Program Files (x86)\AVEVA Plant SCADA\Bin
    CICODEEDITOR =ctcicode.exe
    Config = C:\ProgramData\AVEVA Plant SCADA 2020 R2\Config
    Copy =
    Data = C:\ProgramData\AVEVA Plant SCADA 2020 R2\Data
    Deploy = C:\ProgramData\AVEVA Plant SCADA 2020 R2\Deployment\Client\Projects
    LASTDATABASE =Example
    LASTDATABASEPATH =C:\ProgramData\AVEVA Plant SCADA 2020 R2\User\Example
    LASTSETUPPATH = C:\ProgramData\AVEVA Plant SCADA 2020 R2\User\Example
    Logs = C:\ProgramData\AVEVA Plant SCADA 2020 R2\Logs
    Run =
    Starter = C:\ProgramData\AVEVA Plant SCADA 2020 R2\Starter
    UpdateAnPage = 0
    Upgrade =0
    User = C:\ProgramData\AVEVA Plant SCADA 2020 R2\User
  • Just start the ctdraw32.exe (from the BIN-directory) directly. It will create a default ini for you.
