Hi
I want to install Connector on a server that isn't connected to the internet.
Is there a way to install Plant SCADA / Citect connector V3.0 offline?
Thank you
Hi
Thank you
Hi Hjalti ,
As per the Connector Guide:
Note: .NET Framework 4.7.2, which is installed with Citect SCADA Connector, uses an internet connection. If no internet connection is available, first install .NET Framework 4.7.2. Then install Citect SCADA Connector.
So please install .NET 4.7.2 or higher first, then you should be able to install the Connector without an internet connection.
Kind regards
Olivier
