Hi Team,
There are few Composite Genies in the Library which is not sufficient for the all kind of applications. Please share document to create new Composite Genies as per the User requirements.
Hi Team,
Hi Kaushik ,
I assume you have had a read through the Composite Genie reference in the help:
https://gcsresource.aveva.com/plantscada/WebHelp/plantscada2020R2/Content/Composite_Genies.htm
It will also be beneficial to see the ExampleSA project for example usage and templates which you can then use as a base to build on or customize.
You might also like to see if this this training course could help further:
