Anyone tried using SOEArchive function? I am testing it out and currently getting the error: "Failed to write data - They system cannot open device or file specified. I could not find any reference to this error message.
TIA
TIA
Hi Mark ,
I have seen a report of this error in a previous case. It was related to Citect runtime trying to write a binary file to C:\ and being blocked by UAC of Windows. The work around suggested was:
Please also be aware that archiving will commence according to the values defined for the "ArchiveAfter" and "KeepOnlineFor" parameters. See online help for more info:
gcsresource.aveva.com/.../InitiateArchivingwithaCicodeFunction.html
Hi Oliver,
Thanks for the response. I discovered this myself yesterday, I ran the citect runtime as administrator to check if it is just a file permission issue.
I played around those two parameters and was able to get some archiving after I played around the date time setting on my computer. I tried just to set the computer date to more than a week and got some data archived in the folder.
regards,
Mark
Hello mark ,
i think that i am currently facinf the same problem
i have configured the archiveafter to 0 ,
And keeponlinefor for 6 weeks ,
i made an event as : SOEArchive("C:\Archiving Folder") ,
i took the output of this function and it gives me the number and it gives me the numbe 537
which indicates that the operation wasnt successful ,
and i want to know where i made things wrong ,
because i have enabled the UAC ,
and i dont know exactly what do you mean by running the runtime as administrator , do u mean to login as user who has the role of an administrator ?
and btw i want to know when data are archived they are archived in which format ?
Hi Yahya,
You need to run citect runtime as administrator (windows account). The format is very similar to the database files you see in the alarm server folder.
So I cannot have those archives as excel or text ?
I have run it as administrator but still nothing happens , also I don't see any notification in the soe page , it gives me nothing other than that tye dismount was successful
I didnt know that archiving data was this hard in citectscada
I suggest you keep ArchiveAfter to non zero value and test, do not keep space in the archive path. Also launching runtime with user which is part of Administrators group and login with Citect user which have high privilege can make the difference.
