AlarmSummaries and Journals (SOE)
I am just curious to why the binary files for alarm summaries are separated in folders (AsK0000 - AsK00XX). How are these folders created? Does AsK0000 has the latest alarm summaries?
regards,
Mark
  • Hi  ,
    Are you using both Alarm Summary and SOE pages in your project? If not, you can turn the one you aren't using, by setting one of the following parameters:
    [Alarm]
    DisableSOE = 1
    or
    DisableSummary = 1
    With regards to the folders and binary files created, that is somewhat abstracted by the alarm database backend (managed by ClearSCADA). I think using date / time on the file you should be able to figure out what was the latest.
    But I just wonder what you are trying to achieve? Is it to backup this file so that it can be restored at a later time? I wouldn't recommend manipulating these files directly. It is best to go through official interfaces.
    I recommend reviewing the help topic: System Model > Alarms > Archive the Alarms History > Configure the Archiving Parameters
    Also check out the SOEArchive() function.
    Kind regards
    Olivier
  • Hi Olivier,
    Thank you for your response as always! I got some information from Aveva support about this and everything is clear for me now.
    regards,
    Mark
