I am looking for report generation in PDF on hourly basis . I created one report but it is log all data in a single pdf . I need some cicode type of PDF report generation or in excel
i am very thankful if some one help me out
Hello
I think there is no code for pdf report, but you can use a html report (there is one in the sample project) and then in the last report command execute a printToPDF call
Regards
.PDF is pretty much a standard printer these days.
Create your report in the format that is appropriate - .txt, .RTFor whatever.
Biggest thing is to keep track of what the name is when you print it out. Back when I did it, I was able to print to a file named TempOutput.pdf, and rename it for storage. You will need a .PDF printer that will accept a fixed file name.
