Citect Anywhere Server minimum hardware specifications
What are the Server minimum hardware specifications required for installing Citect Anywhere?
I am looking for minimum CPU, Memory (RAM), HDD size?
The only pre-requisites I can find in the 'Citect Anywhere Server Installation and Configuration Guide - August 2019' are the following:
Prior to installing Citect Anywhere, confirm the following:
- The computer that will host the Citect Anywhere Server is running an operating system supported by Citect SCADA.
- The host computer's firewall is configured to permit inbound and outbound network traffic on port 8080.
- Remote Desktop Services is configured on the host computer.
The Citect Anywhere Server has been tested on the following Microsoft® operating systems:
- Windows Server 2008 R2 SP1
- Windows Server 2012
- Windows Server 2012 R2
- Windows Server 2016
- Windows Server 2019
Citect Anywhere Server needs to be installed on the RDP server where Citect SCADA resides. The Citect Anywhere Server will have minimal impact on the RDP host’s performance and scalability.
Microsoft Windows Server should not be configured as a Domain Controller.
  • Citect Anywhere does not have specific system requirements.
    You can use the Citect Client requirements as a reference for one anywhere client.
    They are in the help, so no specific documentation is needed for Citect Anywhere on this purpose. You can find this information in the following help:
    https://gcsresource.aveva.com/plantscada/WebHelp/plantscada2020R2/Content/Install%20Guide/Runtime-only_Computer_Installation_Requirements.htm
