Using the Kernel on a runtime only client?
Noticing that the Kernel is not accessible on the Runtime Manager Client service.
I thought this was was setup - however, without a project on the machine, the setup wizard is not available.  Citect Studio is not installed, and the project is run in Run/Copy.
I am not seeing any parameters in the citect.ini file that would display the kernel.
And, when I run as normal on the test bench, the button on the upper left will bring up the Kernel for the client.
How can I use the client from the Runtime Manager or add the ability to the runtime?
