Plant SCADA 2020 R2 updating to Update 10
Hi!
I´ve just installed a fresh Plant SCADA 2020 R2 and was going to throw the latest update on it.
But it then wanted me to first update floting license manager and "aveva platform common services".
I downloaded and installed the floating manager no problems, but where is the "aveva platform common services" download?
Iv'e found somehting that might be the upgrade, but that is like version 4.4.7, and I already have 4.6.2.
So i suppose i have the wrong download?
https://softwaresupportsp.aveva.com/#/producthub/details?id=e4563524-e7cf-4c53-024a-08d9609a6c7a
  • Hi  ,
    As Antonio mentioned, the correct download for Plant SCADA 2020 R2 Update 10 is: https://softwaresupportsp.aveva.com/#/producthub/details?id=3f7ab988-9047-4796-7164-08dabb5c214c
    If clicking on the link doesn't work, try copy paste the text into your browser. Might be a glitch with the Support Forum.
    Please note that if you aren't actually using FLM, you can safely uninstall it. If the Update installer detects an old version of FLM, it will block the installation and prompt you to upgrade first.
    On the page, you will see several items:
    PCS_Framework_4.6.2_(x64).zip (required for 64-bit OS)
    PCS_Framework_4.6.2_(x86).zip (require for 32-bit OS)
    Please also note, that there is an Industrial Graphics update, again only install this if you are using this feature.
    So once you have installed the appropriate PCS version on your maching, you may be required to reboot.
    Then the Update 10 should detect all pre-requisites are present and proceed with the update.
    Hope this helps.
    Kind regards
    Olivier
