i want to know if it is scada Aveva Plant Scada can historize data without me buying Aveva Historian software
yes, you can create historical data in many different ways in citect(Aveva Plant Scada) without the need of other software.
for example: event logs, log data to various databases, trends and alarm logs, etc.
Depending on what your logging needs are, you can combine different logs.
Sometimes you may need to use Cicode to create what is desired..
For example: If you already use trends that sample every 10 seconds, but you wish to store long-term hourly average values to an external SQL database.
had any manual, user guide or technical data of the Aveva Plant Scada where it supports that it can record data without other software and storage capacity.
but the draw back is its cyclic from what I hear
Take a look at the alarms and trends sections here: https://gcsresource.aveva.com/plantscada/WebHelp/plantscada2020R2-oct-2022/Content/System_Model.html
