Hi everybody
I'd like to know what the best way is to find all the clients which have borrowed a floating license from the scada server. Knowing the ip address would be enough.
We're using Citect 8.0 (2016)
Thanks in advance
Hi everybody
Thanks in advance
There is no tool available to retrieve such information. But it is possible for you to build one with Cicode function ServerInfoEx(). Take a look at this function in Citect 2016 online help.
Thanks Jacky. I'll check it out and see what happens.
I was trying this today but need some more direction.
With floating licences being issued by the Client process on the server, I used ServoInfo within the kernel of that process. It specified no connected clients though.
I tried the same function on the IOServer, but the connected clients appeared to be more data connections, rather than licence connections. For example, the redundant IO server appeared in the client list a few times. (When that server has its own local full licence).
Any tips on how to identify where the floating licences are issued?
