History files for reports in a multi cluster system
Running a four cluster system where everything is well divided between clusters.  Four machines that run pretty much independantly of each other.  Except thaty are in the same plant, with the same operator.
Daily, weekly and monthly reports are having an issue after a year where they are generated almost randomly (as far as I can tell).
All four clusters were writing to the file simultaneously, and the text was getting jumbled between them.
Are the reports limited to running on only one cluster?  When you assign the process, it asks for the cluster as well.  However, the file belongs to all four clusters.  I'm not sure if the report runs on the report server for the cluster that called it - that is what I would guess.
Can I use a single file to write to from four clusters or do I need to split them out?
