The ExampleSA project in Aveva Scada 2023 uses Alarm_getValue in the variables.
I don't seem to be able to get this to work in a test project. any tips?
Don't seem to be able to find any function called Alarm_GetValue in help.
Hi Tony,
The function is not a built in function therefore it doesn't appear in the help file. The function is defined in the Simulator.ci file under the ExampleSA project. If you don't have that project as an include project you won't be able to access the function.
Hi Clark
Thanks for the reply. Yes that all makes sense now. I had skipped over the simulator file.
