Hello!
Does anyone know if it is possible to read data from a 3rd party system with a restAPI configured in plantscada and write data to IO server?
thanks in advance!
Hello!
thanks in advance!
Hi Eivind Falang ,
The interfaces available to read data from Plant SCADA IO Server are the following:
CTAPI - TagRead
OPC DA Server
OPC UA Server
DDE
ODBC
I recommend you post a suggestion to Plant SCADA Aha Ideas portal (https://plantscada.ideas.aha.io/ideas), requesting a restAPI.
Hi Eivind Falang ,
Plant SCADA supports .Net DLL calls. You could build your own .Net Dll with RestAPI interfaces. Have a look at the discussions in another thread about Rest API. Hope it would help.
RE: Web RESTful service API calls in Citect?
