Plant Scada Access Anywhere with Redundant Plant Scada Servers
I have gone through all the setup and configuration documents related to Plant Scada Access Anywhere but I did not get any information related to Plant Scada Access Anywhere setup with Redundant Plant Scada Servers.
Can anybody share the information ?
  • Hi  ,
    In general, Plant SCADA Access Anywhere (PSAA) can run multiple normal desktop SCADA clients on the same machine via RDS. You should use Computer Setup Wizard to configure it in the same way as you do for a normal client. If you use deployment service to deploy a project with a profile, please refer Citect.ini Parameter Precedence and Profile parameters for more information.
