It's possible install citect Scada 2018 R2 in OS Windows 11? in the original documentatios it's not supported but, i don't know if exist some uupdate
Thanks
Thanks
Hi Andres Rodriguez ,
Citect SCADA 2018 R2 is not officially supported on Windows 11, as that OS was released after. (See the Tech Matrix for details on supported OS or product documentation)
There is no reason why you couldn't install (I don't think the installer blocks you) and it will probably just work.
But you will need to take the risk on yourself, to use this combination. If any technical issue appears, you won't be officially supported with any fix to overcome the incompatibility.
Please also note that Citect SCADA 2018 R2 is in Limited Support and does not receive any Monthly Updates.
Kind regards
Olivier
Hello Olivier, thank you for your response. I'll review the product documentation and do some testing.
Regards
