hello everyone! I want pre approval pop up when I press any command. but i can not able to get the results. I am using YES_NO Function. Can anyone help me. It's urgent. Thanks in advance.
What actual command are you using? What is a YES_NO function? If it is a custom Cicode function, please attach the function code.
Basically, I am using Citect SCADA and I have commands buttons like open close commands and auto manual mode commands.
what I want:
once i will press any button for the command it should show me popup for approval. It will be best for me if citect scada has built in function for that. If not you can provide me with other function or script.
Whereas, I was using YES_NO Function which is built in function in citect SCADA.
Thanks
You could use the built-in Message() Cicode function. It doesn't do Yes/No, but it does have OK and Cancel buttons. It returns 0 if they click OK. So, to use it on a button, set the button command like:
IF Message("title text", "prompt message", 1+32) = 0 THEN
commands if they click OK
ELSE
commands if they click Cancel
END
The 1+32 argument tells it to display OK and Cancel buttons and a question mark icon. See the Message Function help page for details.
The other option is you could use the Formxxx functions to create your own custom form with Yes/No buttons or whatever you want. It is more work than using the Message function. See the Form Functions help page. Start with the FormNew() function.
For example, here is a form function I created that works like the Input() function so I could control the size and position:
//Display an input form similar to the Input() function, positioned near the current mouse coordinates //Returns the value entered by the user or sDefault if the user clicked Cancel. //Sets an error if the user didn't select OK. STRING FUNCTION InputForm(STRING sTitle, STRING sPrompt, STRING sDefault) INT cOkButton = 1; INT cCancelButton = 2; INT cEditBox = 1; INT hForm; INT iWidth = Max(StrLength(sTitle), 24); INT iHeight = 3; INT iMode = 8; INT x, y; STRING sInputBuffer = sDefault; INT nError; INT nPromptLen; INT nLinefeedChar; DspGetMouse(x, y); //If prompt longer than current width, increase width to fit //If prompt has multiple lines, use length of first line nLinefeedChar = StrSearch(0, sPrompt, "^n"); IF nLinefeedChar = -1 THEN nPromptLen = StrLength(sPrompt); iWidth = Max(iWidth, nPromptLen); ELSE iWidth = Max(iWidth, nLinefeedChar); END hForm = FormNew(sTitle, iWidth, iHeight, iMode); FormPrompt(0, 0, sPrompt); FormField(0, 1, iWidth, 1, cEditBox, sInputBuffer, "", 0); FormButton(iWidth - 15, 2, "Cancel", 0, cCancelButton); FormButton(iWidth - 7, 2, " OK ", 0, cOKButton); FormPosition(x + 20, y + 20, 0); nError = FormRead(0) IF nError = 0 THEN RETURN sInputBuffer; ELSE ErrSetHw(-1, nError); RETURN sDefault; END END
Thanks dear, I have tried above first solution it's working.
No words to thanks you.
