How to Convert vijeo 7.5 to aveva plant scada 2023
Hi Good Day to all
My client using Vijeo citect 2015 version 7.5 they need to convert it into Aveva plant scada 2023. how to do it, what issue we will be facing while converting the old system because vijeo 7.5 project contains genie's, super genies, custom symbol citecode, alarm, io server, etc.., how it will converted and is there any documents available. Do i need new license or i can able to convert vijeo 7.5 license to aveva 2023
  • Hi
    What license does the customer currently have? If it is a USB key, it should be possible to get an upgrade code to update the license to the latest version. Please contact your local AVEVA sales contact to get more information about the license update.
    Is there any reason why they have decided on Plant SCADA 2023? It is advised to upgrade to Plant SCADA 2023 R2 (v8.50), as it will have a longer support lifecycle and receive updates for longer into the future.
    There is an upgrade guide available which will walk you through some of the steps required. Do you know if they require zero downtime during the upgrade? If so, the will need to do an online upgrade which may require more steps (hop between the different versions to ensure all data is converted and a success). If they can manage a small downtime they can do an "offline" upgrade or have the ability to put in a parallel system, then it should be very straight forward to get project backup, restore in the new version, fix compile issues, restore old trend and alarm data, then startup the new runtime system.
    Here is the upgrade guide:
    https://docs.aveva.com/bundle/plant-scada/page/1037398.html
    Let me know if you have any further questions.
    Kind regards
    Olivier
  •   Hello, my client has a SCADA in Citec 7.0 running on Windows Server 2003. Now they want to migrate their servers to new ones with Windows Server 2016 and purchased the Aveva Plan SCADA 2023 software. I've had problems with the migration. I don't know if it's Windows, but I haven't been able to do it correctly. Do you have any examples of how I could do it and the considerations?
  •  Rodrigo,  it may also be worth pointing out to the customer that Windows Server 2016 is currently out of Mainstream Support. I would be recommending Server 2022 at minimum, pref 2025 LTSC.
