problème de rollout par xcopy avec les option /s /y /v
Bonjour, je suis entrain de transferer par batch xcopy de mon repertoir projet vers 6 autres machines. la copy se passe bien jusqu'à DIGALM.DBF et se ferme. je demande de l'aide
  • Hello  ,
    This appears to be an IT issue, not related to the product Plant SCADA. You might have more luck posting on a forum that covers Microsoft tools, like XCOPY. I have not used XCOPY in over a decade. There are many options that you control based on your system and requirements. Have you experimented with other options like /C and /D ?
    What happens if you try to manually copy the files across your network using Windows Explorer? Are there any errors or issues? Is any process on the remote machine opening the file with the issue?
    There is an easier way to rollout your SCADA project to your machines now. Please have a look at the Deployment feature.
    https://docs.aveva.com/bundle/plant-scada/page/1096408.html
    Wishing you luck in getting the best solution.
    Kind regards
    Olivier
  • Hello Olivier,
    Thank you very much for the promptness. No, I haven't tried other options. But I can copy through Windows Explorer. once copied I run the project normally My digalm.dbf file seems heavy (5.5MB). I'm going to try the deployment. best regards
