AVEVA is looking to understand how customers are using the Equipment model. If you would be open to sharing your Plant SCADA application, and are using Equipment, we would welcome the opportunity to analyze your shared project internally.
AVEVA is looking to understand how customers are using the Equipment model within your project specific use case.  For awareness, Equipment definitions create logical groupings that allow you to organize your project using a hierarchical design. Each definition brings together the base SCADA properties into a single entity that can be easily replicated within your project. If you would be open to sharing your Plant SCADA application, and are using Equipment, we would welcome the opportunity to analyze your shared project internally only, and how you are leveraging this feature to it's fullest capability. Please Private Message or email me if interested. Thanks!
  • Nathan - I have used equipment successfully on quite a few projects.  It becomes especially useful when you want two structured tag references to an item.  Mostly on I/O. A limit switch or solenoid is generally referenced by it's tag name, but a set of supergenies can give access to an entire I/O card with proper controls and tags through the equipment, and the pages are transportable between projects.
    Unfortunately, I have not had it give much advantage over giving the same PLC reference to two tags, except for the fact that you can see them together.  Much easier to edit.  The features of the equipment are documented on how to enter them into the program, but I have net been able to dig into the structure deeply enough to see what they do.  Digging into the Help is pretty much useless, and tight time tables on jobs doesn't allow much time for experimenting and "reverse engineering".
    It does seem to have potential for solidly structuring similar devices.  The example project seems to use it to a limited degree.  A few diagrams showing the relationships and references of the fields would be great.  I have always wished that the relationship between tags and alarms was relational, and the equipment seems to provide a path to that if I can find it.
  • Hi Dane,
    Thanks for your feedback. Make sure you keep up-to-date with the monthly updates for your version. There were some issues with the Equipment Editor that have been addressed.
    In general,
    • We don't save parameters with empty values to the DBF, regardless of whether that's the default or not
    • Adding a new instance in Studio won't add any parameters (until its opened and saved in EE)
    • Adding a new parameter to a type with a non-empty default should add that parameter for all instances (just tested this one)
    I can't remember the specific reasoning on pt1. I take it from your feedback, that having blank defaults is pretty common for you?
