Is there an option to run a backup of a Plant SCADA project using ctback32.exe without including the Database Name?
I would like the ability to run CtBack32.exe silently with options to back up the current selected/running project.
The two ways that have worked so far is to use the -d<Project Name> option or to include DATABASE=<Project Name> in the Citect.ini file.
This requires every PC to be manually configured whenever there is a project name change.
Note: Citect.ini does have a parameter called LASTDATABASE=<Project Name> that holds the current running project.
