Deployment server + client issues after updating plant SCADA 2023
Hello gentlemen, I have an issue with the deployment server after updating to U6 and U7 after it also, the issue is that when I trigger an deployment operation from server to client, the project is not being transferred correctly to the shared folder between the two of the PCs, and the size of the project will be as little as 110 KB, but previously when the deployment was working properly, the size of the project was 600 MB approximately. and because of this issue, after deploying the project and heading to the setup wizard to configure runtime manager to run the deployed project, when you choose the project and the version required, a popup error will show up and it says "The Setup Wizard cannot locate your Citect.INI file." another popup also shows up says "Cannot Continue with the setup. cannot load screen profile".
Note : I use my own profile and not the default citect.ini profile and i configure this when trying to deploy in the field.
Note : Deployment in plant SCADA was not working properly right after the update and when I enter the password and username of my administrator there was an error says that service is not available and I solved this problem after noticing that Identity manager service was not running.
