i am in the middle of upgrade Citect 2018 to Plant Scada 2020R2, i have rolled most of my clients out to 2020R2 a few to go.
Primary Server is running 2020R2 Backup server is Citect 2018. i am unsure if redundancy is correct and want to know what are the key things to check to ensure redundancy between servers on different versions in the interim phase. earliest version in the ini file is set to 8100 , what other parameters and setting do i need to check.
my question is
my primary server (2020R2) project network addresses are in the machine name format AB1CD234EFG whereas my Backup server( 2018) is in the IP address format 10.11.12.13
i have noticed some odd behavior with alarm handling between servers and clients when the primary is running.
should i change the 2018 to reflect machine name format and will it compile? thanks in advance.
