Hi Charles ,
Check the Project > Parameters for the following:
[Page] AddDefaultMenu
By default it has a value of 2, which is why you see that additional "Pages" menu, even though none is defined in the menu navigation.
Set it to 0 to disable this.
You can either modify the parameter in the project, or the citect.ini file (for each machine). Please note that the Citect.ini will override the setting in the project parameter.
Kind regards
Olivier
Thank You, worked great
